my250r11
Sawhorse
Back to it depends on the AHJ. We have a lot of clay here and per an engineering report adopted long before I got here, due to the differential settlement we require 24"D X 12"W footings with a minimum of 2 #5 rebars.
This sounds like you are imposing requirements that are not stated in the adopted building code. What am I missing?Back to it depends on the AHJ. We have a lot of clay here and per an engineering report adopted long before I got here, due to the differential settlement we require 24"D X 12"W footings with a minimum of 2 #5 rebars.
What you are probably missing is that based on the finding of the engineering report, the municipality had their engineer review it and come up with an amendment to the building code which they adopted by ordinance for the good of the community. Perfectly legal. You read into it your way and I will read into it my way.This sounds like you are imposing requirements that are not stated in the adopted building code. What am I missing?
LA County has the entire range of soil types. Long ago it was decided to classify every property as expansive soil. An applicant has the option of producing an engineered soil report or follow a standard plan of 24”D x12”W with 2-#4 rebar at the top and 2-#4 rebar at the bottom.Back to it depends on the AHJ. We have a lot of clay here and per an engineering report adopted long before I got here, due to the differential settlement we require 24"D X 12"W footings with a minimum of 2 #5 rebars.
As jar546 said it was legally adopted thru ordinance. We are not allow to be less then what the State requires but we can adopt more restrictive requirements if needed. During the process the lawyers look it over as well. Wouldn't be any different than Code Enforcement enforcing weeds, trash & debris ect. I'm not a lawyer any more than i'm an engineer. If it's adopted building code it my job to enforce that code. No more & no less either. Some of us do know how to stay in our lane.This sounds like you are imposing requirements that are not stated in the adopted building code. What am I missing?
My lane was wide.Some of us do know how to stay in our lane.
