EnvisionMan
Member
Having a serious issue with designing an over/under duplex. Side-by-side duplexes are a breeze, but this project is becoming a challenge.
We have selected a good 1-hour assembly for the ceiling/floor. No problem. We have also selected a good 1-hour wall assembly for the exterior walls. No problem again. However, the builder does not want the interior, non-load-bearing walls to be fire-rated. He wants to use 1/2" drywall and not worry about using all the fire-rated mechanical things (metal j-boxes, fire caulking, etc).
So how can you build a non-load-bearing, non-fire-rated wall under a fire-rated assembly? There are serious issues when it comes time to actually constructing it. The drywall (we are using a double layer of 1/2" drywall) cannot be broken for anything but a 1-hour fire wall. But all the wiring in the ceiling/floor assembly has to be roughed in before the sheetrock is put in place. But the non-load-bearing wall has to be installed UNDER the sheetrock.
See the problem?
In order to run a wire from the switch to the ceiling light, I have to have the wall in place. But in order to have the wall in place, I have to have the sheetrock in place between the ceiling and wall. But in order to install the wiring I can't have the sheetrock in place.
What gives?
See the problem?
What gives?
