NYC kitchenette dropped soffit
masterbuilder
New York City
The latest NYC building code, requires kitchenettes, (which in nyc are any kitchens under 80 sf, thus not required to have natural light and air) to have a 12" dropped soffit. In other words, if your kitchenette is open to your living room, and no walls surround it, you need to at least have 12" of soffit in the ceiling.
Anybody familiar with this, and any ways around it?
Odd, does it say where the soffit should be and how wide it should be? Above the wall cabinets, counter, island, stove, sink, over doors or between rooms?
How do you measure the kitchenette if there is no wall?
Can you post the wording in the code section
What I figured,,, smoke soffit​
Kitchenette Soffits​
A soffit is a drop down portion of ceiling. In a kitchenette it is mandatory to have a minimum 12″ soffit around the perimeter of the kitchenette.
1211.2 Kitchenettes in multiple dwellings.
Except at entrances thereto, every kitchenette in a multiple dwelling shall be surrounded by partitions extending from floor to ceiling, and/or by a soffit dropped 1 foot (305 mm) from the ceiling
yes this is the current rule, and it describes in general the separation between a kitchenette and living space, for the purpose of measuring minimum dimension. I just cant grasp the whole 12" dropped soffit, when required etc. its clearly required in the latest code, but the project I am working on is a prior code, and there is no reference of this soffit in that code.
Is your current job permitted under the prior code ??
What year did they adopt the latest code?
Yes my current job is permitted to be reviewed under prior code, 1968. Latest code was adapted 2014. However in NYC there is also a multiple dwelling law and a housing maintenance code that both reference this kitchenette rule, that a kitchenette needs to have walls around it except at the door. Common practice is instead of the walls , Dept of building allows this 12" soffit, which is meant to keep smoke within the kitchenette as it does not have a window for ventilation.
w
1203.4.1.4. Kitchenettes in R and I
1 occupancies.
Kitchenettes in R or I
1 occupancies shall be provided
with natural
ventilation in accordance with Section
1203.4.1.4, unless pro
vided with exhaust ventilation in accordance with the
New
York City Mechanical Code
. Openings providing required natural ventilation shall be windows.
Exception:
Openable skylights may be substituted
for windows provided that:
1.
The kitchenette is on the top
story;
2.
The skylight is 12 inches (305 mm) in its least dimensions;
3.
The skylight is at
least
4 square feet (0.37 m
2
) or one
eighth of the area of the kitchenette, which
ever is greater;
and
4.
The skylight provides ventilating openings for at least one
half
of its area.
1203.4.1.4.1 Minimum opening.
The minimum openable area to the outdoors shall be 5 percent of the floor area of the
space being ventilated. Every win
dow or other opening providing required natural ven
tilation shall be at least 1 foot (305
mm) wide and at least 3 square feet (0.28 m
2
) in total area, providing a minimum of 1
½
square feet (0.14 m
2
) of openable
area.
Exception:
Skylights shall comply with the
exception of Section 1203.4.1.4.
1203.4.1.4.2 Adjoining spaces.
Natural ventilation fo
r kitchenettes shall not be through openings off another room or
space.
Exception:
A kitchenette may open onto a par
tially enclosed balcony or space above a setback conforming with
Exception 2 of Section 1203.4.1.2.2.
story;
2.
3.
The skylight is at
least
2
) or one
ever is greater;
and
4.
half
of its area.
2
½
square feet (0.14 m
2
) of openable
area.
Exception:
space.
Exception:
Law
1 occupancies.
with natural
New
Exception:
1.
story;
2.
3.
The skylight is at
least
2
) or one
ever is greater;
and
4.
half
of its area.
2
½
square feet (0.14 m
2
) of openable
area.
Exception:
space.
Exception:
I get all this, its not about the ventilation or light and air. A kitchenette in nyc is a kitchen that is under 80sf, and it does not need to comply with light and air thus its not considered a habitable space or required to have a window as long as its under 80SF. What is driving me nuts is this requirement for a 12" soffit. I think its more of a fire and smoke spread device and requirement then anything else. Ill figure it out, ill post on here if I find a definite answer.
