rth
Bronze Member
2006 IFC
Building fully sprinkled A-4
7772 sqft skating arena
2970 sqft common area outside the arena with loose bench seating
kitchen, office, front desk, dj booth, skate distribution area occupancy = 10
Building designed and primarily used as skating rink. Occasionally used as dance hall. Occupant load as skating rink = 363 calculating common area at 15 sqft despite loose bench seating. Any help there appreciated
Main problem = when calculated as dance hall the skating area = 1110
Assembly with over 1000 occupant load opens many more requirements many of which I haven't looked up yet. Is it feasable to give them an occupant load reflective of what the building meets as far as code requirement? In his case I think it would be 999, means of egress is met but alarm is not voice NFPA 72 compliant based on 1000 occupant load. Or do you tell him to be used as a dance hall he must bring the entire building up to code based on the occupant load of 1318?
TIA
TIA
