Blazer
GREENHORN
My code approach is to call the fifth story addition a story which only takes up a third of the existing roof of a four story building. The existing roof was an occupied roof previously but the plans to alter the building included an addition of bathrooms to the occupied roof and a lounge while also extending the elevator to it. The outdoor space is increased in size but since enclosing occupied space I now have an added story (5th) for the enclosed portion. Since construction is III-A and sprinklered Table 504.4 (IBC 2018) limits the office building (Mixed-Use Separated with Groups A-3 and B) to six stories and the occupied roof can be Assembly if permitted in the story below which is capped at four stories by Table 504.4
My code official accepted the enclosed lounge and bathrooms as Business and not Assembly if not more than 750 SF and less than 50, but indicates the outdoor space is not an occupied roof, but is considered a story even though its on the roof of the fourth story. As far as I'm concerned they have not provided code section that prohibit an occupied roof and a story at the same elevation. The plans do indicate a structure for solar panels that is elevated high enough off the roof that occupants can occupy the space underneath so they said solar panels make it a roof so the roof below it becomes a story. Even if removing the solar panels and its structure they wont consider it an occupied roof with Assembly occupancy.
Does my occupied roof now become a story when completely outdoors and on top of a roof? I thought story was defined as distance between floor below and floor/roof above. I have never come across a floor that has roof drains before, LOL. Let me know if I'm wrong to assume the two can exist at the same elevation.
