Project was in design in 1972. Therefore, the Standard Building Code in use was prior to 1972. I need to know the allowable building area and construction type for an Assembly building. I think it would have been one of the Assembly occupancies without a stage. Occupant loads based on my oldest code copy (SBC 1997) classify Large Assembly and Small Assembly and Construction Type II-uns (un-sprinkler) as the minimum. The building is 3-stories and around 27,600-sf. I think the number of stories is going to determine the construction type. I just need to determine what the minimum Construction Type would be. The building is all concrete framed floors and structure and the exterior walls are non-combustible. There is nothing on the drawings to indicate any fire proofing/protection compliance. The Structure does not have a fire suppression system. It does have a 3-story open center stair and three other EXIT Stairs that are enclosed. Mechanical and elevator shafts are shown to be 2-hour rated. It is a college Student Union with a lot of assembly spaces, book store and some other type of shops and offices. We are going to add onto it and I see a firewall will be needed due to limited funds will not allow fire suppression in the existing building.
Research must be using the Standard Building Code prior to 1972. Also known as the Southern Building Code but that name was changed to Standard Building Code years ago.
Thank you for any help.
