Old stairs
Oh Well
I am sure that most of you inspectors have encountered renters that call the building dept with a complaint. The typical scenario is a renter that has become a defaulter and is being evicted. As a parting gesture the jester decides to turn in the owner for anything and everything that they can come up with. It is usually stuff like water heaters and el service upgrades. Now and then it is a room addition or a converted garage.
Recently I fielded a doozy. The woman said that her daughter fell on the stairs and the stairs do not meet code. The year was 1985 when risers could be 4" t0 7 1/2". There is a permit and it has a final approval.
Bottom riser
http://www.flickr.com/photos/97859466@N05/10007911565/ [/URL]
Top riser
http://www.flickr.com/photos/97859466@N05/10007962186/
Eleven risers total. Two meet code.
This is a set of four that lead to the dirty eleven.
http://www.flickr.com/photos/97859466@N05/10009572084/
I don't think that I would trust the handrail but I don't want to rip it off the wall....at least not until they start building the new stairs.
Bottom
http://www.flickr.com/photos/97859466@N05/10009691283/
Top...and yes, that's a hair ball.
http://www.flickr.com/photos/97859466@N05/10009643166/
She hit him where it hurts.
To add insult to injury, the landlord will have to put them up in a hotel while the work is done. Probably have to feed them too. And trust me, that will cost more than the hotel. And oh my goodness, they have a bunch of dogs.
I thought during that time frame you could 8 1/4 x 9.
Trying to find archival proof.
Brent
http://www.asse.org/practicespecialties/engineering/docs/Stair%20Safety.pdf
1.0 INTRODUCTION
For the first time in any U.S. model building code, the 1992 edition of the BOCA National
Building Code requires residential stairs to have risers no greater than 7 inches and treads no less
than 11 inches. Before 1992, the BOCA code specified 8¼-inch maximum riser heights and 9-
inch minimum tread depths. This 7-11 geometry, as it is known, has the potential to influence
housing costs significantly, particularly the cost of entry-level affordable housing.
MASSDRIVER said:
I thought during that time frame you could 8 1/4 x 9.Trying to find archival proof.
Brent
1.0 INTRODUCTION
We have a copy of the UBC from 1985 and that one says 4"to 7.5" riser and 10" minimum tread.
Thanks for the link. Somewhere here at the forum is a link to a video of a stairway with a wrong step. The riser is off but not by much. It is at a mall. The number of people that stumbled is surprising.
I haven't found the link but I did find this:
This is the commercial that came with the video. If fatboy sees this he might not have to light a magazine on fire anymore.
Poop
I'm pretty sure I love her. Crazy a55 redhead.
I'm going to buy some of that stuff for the next time I have to launch a democrat.
Uh, ahem... I wonder what fraction of an inch caused that stair tripping disturbance.
Brent
Ice, when you get a chance would you look in that ubc and see if there is an exception for R-1?
When I was young I did quite a few 8 by 9 stairs and I'm just wondering where that came from.
For 8' walls and 2x10 joists this came to a tidy 13 steps on the money with 9 feet of run. Did a lot of those on town houses.
Brent.
MASSDRIVER said:
Ice, when you get a chance would you look in that ubc and see if there is an exception for R-1?When I was young I did quite a few 8 by 9 stairs and I'm just wondering where that came from.
Brent.
I will be looking at that code and quoting it chapter and verse for the landlord. I would be surprised if there is an exception but I will look for it.
And here it is Brent.
EXCEPTIONS: 1. Private stairways serving an occupant load of less than 10 and stairways to unoccupied roofs may be constructed with an 8-inch maximum rise and 9-inch minimum run.
I forgot about private stairways a long time ago. The problem is the huge difference between steps. 1 5/16"
ICE said:
And here it is Brent. EXCEPTIONS: 1. Private stairways serving an occupant load of less than 10 and stairways to unoccupied roofs may be constructed with an 8-inch maximum rise and 9-inch minimum run.
Yea. No exception for that. Whoever built them overthought the floor covering I think.
And to amend, before the 1985 ubc it was the 81/4" riser that worked perfectly. Afterward you had to add a step. That's why there are all those horrible unwalkable stairs in the old cheap townhouses.
Brent.
Eight inch rise was always the max not 8 ¼" in CA for residential/private.
UBC 1937
.......The rise of stairway shall be not more than seven and one-half
inches (7 1/2") and the tread exclusive of the nosing not less
than ten inches (10") (maximum pitch 37 degrees), and there
shall be not more than 17 risers in any one run between landings;
provided, that stairways in dwellings and stairways serving
mezzanine floors may have a rise of not more than eight inches
(8") and a tread exclusive of the nosing of not less than nine
inches (9").
Dwelling Construction Under the UBC 1976 Edition
The rise of steps in a stairway shall not exceed 7 1/2 inches and the run
shall be not less than 10 inches. Variations in the height of risers and the
width of treads in any one flight shall not exceed 3⁄16 inch. [sec. 3305 ©]
EXCEPTION: In private stairways serving an occupant load of less than
10, the rise may be 8 inches and the run may be 9 inches.
Is there a statute of limitations on discovering things approved in error and still being able to compel compliance? It is 2 years in most cases in VA.
Also it appears that the bottom riser height may have been reduced by subsequent floor covering additions.
Here's another set of old stairs...90 years old.
If something was approved in error, it was never legally approved.
Regardless of the rise and run minimums and maximums, the variation in riser heights is the key to safety. Whether or not the code in the day was 8/9, 7/10 or whatever, I really doubt that the variations you have there EVER met code. It is a trip hazard.
Didn't the 3/8" variations come in with the I-Codes? I have heard that there was no variation allowed under the UBC.
97 UBC had the 3/8" in there also......as far back as 1979 it was in the UBC, jumped back to 1967 and it was 3/16"
pete_t said:
Eight inch rise was always the max not 8 ¼" in CA for residential/private.UBC 1937
inches (9").
Looks to me like more than 3/16" variation in the flight.
So, does the exception speak to the variance in rise/run? Or to the just exclusively to the rise/run limitations? Or is it silent? ........looks like silent in peaches citation.
The exception does not mention the 3/16 so it is still enforced.
In the 1937 UBC citation there is no variance limitation listed. I do not see it specified, so it appears there is no limitation, as long as the rise/run is compliant.
It's an unwritten rule.
it's the sum total of variance within a flight. If the variance in three risers in a flight are each 1/16", the other risers better be absolutely consistent.
