Onsite POT striping required?
ADAguy
Anyone ever seen in ADA Standards for Accessible Design, the CBC, ANSI 117.1 or elsewhere a codified or legal requirement to provide striping of onsite POTs from the public sidewalk to the primary entrance of a service station min-mart?
Given it not being a technical requirement then how do you provide tactile indicators for cane users?
There is no code requirement for POT to be painted.
The painting is a convenience for the disabled and the Inspector.
Truncated domes are not dependent on the painted POT. The blind person
cannot see the paint anyway.
I have had rehab projects where there was a but a single 4' wide pathway that would comply for both forward and cross-slope as it meandered across a large warped asphalt surface. In that case, we striped the meandering route that we knew would comply, just let people know that a compliant path was possible.
Mark, see 11B 247.1.2.5; what say you to it?
11B-247.1.2.5 Hazardous vehicular areas. If a walk crosses or adjoins a vehicular way, and the walking surfaces are not separated by curbs, railings or other elements between the pedestrian areas and vehicular areas, the boundary between the areas shall be defined by a continuous detectable warning complying with Sections 11B-705.1.1 and 11B-705.1.2.5.
It does not say TD shall or should be "IN" vehicular traffic POT. The "boundary" not the vehicular traffic POT. if you follow the manufactures instructions you will not place them in a vehicular traffic POT. They will not hold up to vehicular traffic, follow the manufactures instructions.
I believe that section says you need them at the "boundary" (pedestrian to vehicular) not over the entire path...
The point that I have been trying to make is, they should never be in the Vehicular POT
These are wrong: DO NOT DO THIS\
The one on the top was used to advertise their innovative solutions to the ADA issue.
"Point" not mentioned before, "required driveway width", how is "required" driveway width determined for a gas station?
Are all driveway entrances assumed to be bi-directional (in most cases)?
