Yikes
1016.1 exc. #2 uses the term "open exit access components". Is it possible to go outside and re-enter a building corridor system multiple times as long as you are less than the maximum allowable exist access travel distance (Table 1016.1)?Or instead, once you gone outdoors, you must call it an "exit"? Where in the code is "open exit access components" discussed?See the attached file for an example: a daisy-chain series of upper-floor small office spaces with corridors, using interconnecting open-to-the-sky patios as part of the exit access system. The last one goes downstairs, then also goes through an office space WITH a corridor (sorry, forgot to draw it in there). Does this work?
20110214115136334.pdf
