"Outdoor" Heaters
steveray
West of the river CT
Seems like there is a bit of a disconnect here...where we have to force people to build higher and higher performance buildings to save energy, but they can heat a sidewalk or deck or patio, as long as it is not enclosed...?Where is the conservation in that?
Steve,
Next code cycle most likely. Some day soon; it will be illegal to rub two sticks together.
SShhhhhhhhh, :)
Uncle Bob
We use Buffalo chips in the outdoor fire pits :D
A buffalo chip, also called a meadow muffin, is the name for a large, flat, dried piece of dung deposited by the American Bison from the large amount of grass that it eats. Well dried buffalo chips were among the few things that could be collected and burned on the prairie and were used by the Plains Indians, settlers and pioneers, and homesteaders as a source of cooking heat and warmth.
MLC,
Buffalo Chips ain't very nutrtious; but, in a pinch, a little cream gravy with gopher grease goes a long way.
Uncle Bob
Its Green Its Sustainable Its Eco Friendly-
It save all the building materials
All the transportation of the materials
eliminates construction debris
reduces impact at the landfill
Its practically Carbon Nuetral
Did I skip any BUZZ words
And JP
Gives new meaning to phrase
FIRE IN THE HOLE!
I am not sure if you missed any buzz words, but you are certainly being proactive instead of reactive as it relates to this paradigm shift. Your thinking outside the box shows as well.
Hey the quote for the fire wall on top of the pool fence was north of 7K. Might have to do that myself.
Since I'm connecting to a portable propane tank does one need a permit?
It depends--
IF it is build in and attached to the fence then a permit would be required just like a built in grill.
IF it is a portable appliance that is set on top of the fence and fed by a portable tank then no permit would be required just like a portable grill.
The portable device would come under 2006 IFC section 308.5.2 that requires it be installed in such a manner as to prevent flame from contacting combustible materials
307.4.2 would seem to indicate it also has to be 25 ft away from structures.
Hey guys watch this marshmallow roaster I built that works from 15 feet away.
FredK said:
Hey the quote for the fire wall on top of the pool fence was north of 7K. Might have to do that myself.Since I'm connecting to a portable propane tank does one need a permit?
