o_m_r
I'm a new home owner who's recently become interested in DIY and homebuilding best practices, and wondering the best way to resolve some apparent code violations after multiple contractors have done work on a structural wall during our still in progress bathroom remodel.
The wall involved is a 2nd floor interior bearing wall consisting of 2x4 studs, 16 O.C., with 3/8" OSB sheathing.
photos:
https://www.dropbox.com/s/e3k8gf31e93tfng/7w%B6h4uTeuJezYExK%XKQ_thumb_a52c.jpg?dl=0
https://www.dropbox.com/s/g54r1flq7t630gt/UNADJUSTEDNONRAW_thumb_a554.jpg?dl=0
https://www.dropbox.com/s/icti6394dstwwbj/GNywSBlKRByrdUrYEqjkKw_thumb_a45f.jpg?dl=0
My area has not adopted Ch. 11 on of the 2012 IRC and so the 2012 UPC covers the plumbing.
Without getting into how the cuts and holes got there, although I will if asked
, as shown in the photos, I’ve got 3 "successive" studs cut and/or bored beyond 2012 IRC limits.
I plan to add 1 full height stud to the stud cut through at the far left for electrical (switch bank), toe nailing to top and bottom plates, face nailing to the original stud, gluing the narrow side to the sheathing and adding Simpson’ A35’s to reinforce the new stud to the sheathing.
That leaves me with 2 successive studs ( 1 single and a pair of doubled studs at the edges of 2 panels meeting).
The horizontal vent line ( 1-1/2” ) is fine in the sense that I can easily install stud shoes for each penetration, as explained in the exception for 2012 IRC, Ch. 6, R602.6.
However, with the lower penetrations for the drainage line ( 2” ) I can’t install stud shoes on theses studs because on the single stud, the hub of the combination wye fitting will conflict with the rim of the Simpson’ HSS shoe, and the doubled studs have so much material removed that I can’t fasten all the screws.
Beyond that, both the single and doubled studs have conditions where it might be necessary to install additional shoes or some other repair, i.e. for the empty bored hole in the single stud, and the hole being too large for a stud shoe in the doubled studs.
I could add a new separate stud to take the place of the single damaged stud, and have room for stud shoes for each notch of the DWV piping, and it would be 16” O.C. from the new stud I’m adding next to that first cut stud from the electrical work. However, I’m thinking I’d need to remove the drywall from other side of the wall and properly nail the sheathing to this new stud, which for obvious reasons I’d rather avoid. Unless using A35’s would be sufficient to secure the sheathing to the stud?
For the doubled studs, I’m at a loss for what would be a sufficient repair other than completely replacing them, which would for sure require me to nail the sheathing to the new studs from the other side of the wall since these are supporting the edges of the panels.
Adding a stud to either side of the doubled studs still leaves me with one side where the stud shoe can't be fully fastened, and no one makes a stud shoe for (4) 2x members if I tried to add studs to both sides.
I'll put nail plates over the PEX supply lines in the doubled studs, or wherever else the IRC and UPC require.
Is remove and replace the studs my only option? My best option?
Any advice and opinions would be greatly appreciated.
photos:
