Micahkl
Hey had a quick question about the laundry P trap I'm installing. The corner turn is a bit too short to fit with a completely vertical pipe into the P trap, is the slight offset I've got, as the photo shows, going to be OK as long as the P trap itself if level? Or would it be ok to overbore the stud slightly so the female end fits in the stud and then put a stud shoe on it? That would make the vertical pipe complete straight. The wall is not load bearing.
