Patio fire pits
rktect 1
SILVER MEMBER
Illinois
I am just wondering what everyones take is on section 307 of the 2006 IFC.
We did not issue permits for patios until recently. There have been a couple that included wood burning fire pits. According to 307, the fire pit can not be located within 25 feet of any structure. So how does everybody else handle this? What about a gas log fire pit? How about exterior fireplaces?
the definitions should provide guidance --- and some limitations on government intrusion
SECTION 302 DEFINITIONS
302.1 Definitions.
The following words and terms shall, for the purposes of this chapter and as used elsewhere in this code, have the meanings shown herein.
BONFIRE. An outdoor fire utilized for ceremonial purposes.
OPEN BURNING. The burning of materials wherein products of combustion are emitted directly into the ambient air without passing through a stack or chimney from an enclosed chamber. Open burning does not include road flares, smudgepots and similar devices associated with safety or occupational uses typically considered open flames or recreational fires. For the purpose of this definition, a chamber shall be regarded as enclosed when, during the time combustion occurs, only apertures, ducts, stacks, flues or chimneys necessary to provide combustion air and permit the escape of exhaust gas are open.
RECREATIONAL FIRE. An outdoor fire burning materials other than rubbish where the fuel being burned is not contained in an incinerator, outdoor fireplace, barbeque grill or barbeque pit and has a total fuel area of 3 feet (914 mm) or less in diameter and 2 feet (610 mm) or less in height for pleasure, religious, ceremonial, cooking, warmth or similar purposes.
EDIT: Coug Dad beat me to it....
We are using the 2010 CFC (based on 2009 IFC).......
If wood burning, keep it 25' away
Fireplaces do not fall under "Recreational Fire" (see definition of Recreational Fire)
We allow gas fire pits closer than 25', our interpretation is that they are not "burning materials other than rubbish..." no embers, etc.
bbq grills, bbq pits and outside fire places are not regulated as recreational fires so the 25 foot rule does not apply
That is our interpretation as well. If the structure is over 6 feet in height (e.g., outdoor pizza oven, etc.) we have some zoning setbacks from property lines and foundation requirements, but that is about it.
beach said:
What about a "Fire Pit" that is not used for cooking (BBQ grill, BBQ pit)?
you mean kind of like a 5 gallon plastic bucket of sand on the back porch used for cigarette butts, or an 18" masonry pit with(out) wire mesh cover built into the patio?
What hazard is present in a small fire pit not used for cooking that is so different from one used for cooking that you want to apply more strict requirements to the one not used for cooking?
302 Recreational Fire. An outdoor fire burning materials other than rubbish that is not contained in an incerator, outdoor fireplace, portable outdoor fireplace, barbeque grill or barbeque pit and has a total fuel area of 3 feet or less in diameter and 2 feet or less in height for pleasure, religious, ceremonial, cooking, warmth or similar purposes.
You tell me, I'm just reading the code. Do I want to apply more strict requirements than the code? Nope, unless you think I am interpreting those sections incorrectly..... if so, please let me know.
307.4.2 Recreational fires. Recreational fires shall not be conducted within 25 feet of a structure or combustible material.
The OP referred to "Fire Pits" not BBQ grill or BBQ pit
rktect 1 said:
I am just wondering what everyones take is on section 307 of the 2006 IFC. We did not issue permits for patios until recently. There have been a couple that included wood burning fire pits. According to 307, the fire pit can not be located within 25 feet of any structure. So how does everybody else handle this? What about a gas log fire pit? How about exterior fireplaces?
I think I'd let the fire department deal with enforcement rather than requiring permits.
I've never been questioned about a fire pit before, but in your quote it says "outdoor fireplace," wouldn't a fire pit be the same or similar to a fireplace since you can burn wood in it? just my humble thoughts on it ....
I'd call it "an open air smoker."
I have to work with our fire department on a few things. This is one of them. Instead of sending permits to me for review, then to fire, we decided that I was capable of writing the note for the 25 foot requirement. Probably saves the residents here an extra day for review just for that one note.
