BayPointArchitect
Sawhorse
While attempting to determine the rate of absorption, I dug nine holes and filled them with water. I am told that a value greater than 60 MPI is cause for concern. If my MPI is based on the four hour measurements, I have 10 MPI - which is good. Obviously the absorption rate slows after the soil surrounding the hole becomes saturated after 24 hours. So what length of time should I be using?
https://www.dropbox.com/s/qiqeogrikw2bp66/PercolationTest.pdf?dl=0
Thanks again!
ICC Certified Plan Reviewer
Thanks again!
