Piercing saddle valves
Iowa49
Are any of these approved, the 2006 IPC appears to forbid them, but I continue to see them used. Do any of you know if they are actually approved by listing for use in water systems. They're used for ice makers and humidifiers primarily.
Re: Piercing saddle valves
Iowa49,
Welcome to the "new" Code Forum! :)
While the IPC does not [ typically ] allow them, it will be up
to the AHJ if they are allowed or not. Check with them!
If you are the AHJ, then your city officials will need to
decide if they are accepted or not.
I really don't see a problem with them. They have to be an accepted, they're manufacturing them! :roll:
I look at it this way....what does it hurt?
The indented pipe causes tubulance in the flow of the water which then cavitates the pipe down stream from the puncture, causing holes to appear and leaks. It's the same reason pipe needs to be reamed after cutting.
