Polyethlene storage
Inspector 102
N/E Indiana
Local industrial plant has asked me how much poly they can have on hand. Currently under 2006 IFC and when I read Chapter 23 my head starts to spinning rapidly. They have rolls of poly film that they wrap under their finished product for palletizing and protection. The poly wraps pallets of silicone rubber which is a Broup B plastic. The poly seems to be a Group A plastic and this is where I get lost. How much, by volume or weight is acceptable before it goes to a high hazard commodity? I am the building official and fire inspector told them to ask me. Not alot of assistance from that side, but he is new. Any guidance appreciated.
According to Section 2303.6 [ `06 IFC ], polyethelene is already a
high hazard.
Section 2303.6 High-hazard commodities.
High-hazard commodities are high-hazard products presenting special fire hazards
beyond those of Class I, II, III or IV.......... Group A plastics not otherwise classified
are included in this class.........Examples of high-hazard commodities include, but are
not limited to, the following:
Aerosol, Level 3 (see :Next('./icod_ifc_2006f2_28_sec001.htm')'>Chapter 28)
Alcoholic beverages, exceeding 80-percent alcohol, in bottles or cartons
Commodities of any class in plastic containers in carousel storage
Flammable solids (except solid combustible metals)
Glycol in combustible containers (50 percent or greater)
Lacquers, which dry by solvent evaporation, in metal cans or cartons
Lubricating or hydraulic fluid in plastic containers
Mattresses, foam rubber or foam plastics
Pallets and flats which are idle combustible
Paper, asphalt, rolled, horizontal storage
Paper, asphalt, rolled, vertical storage
Paper and pulp, rolled, in vertical storage which is unbanded or not
protected with an approved wrap
Pillows, foam rubber and foam plastics
Pyroxylin
Rubber tires
Vegetable oil and butter in plastic containers
It is the storage arrangment that determines whether additional requirements apply, not weight or volume of the commodity being stored. If they stay under 6' in height, they're fine (see definition of high-piled combustible storage). If they exceed 6' in height, see table 2306.2 for additional requirements depending on square footage of the high-piled storage area.
As stated above chap 23 is more of how to store stuff, and indirectly may limit some but not much
And as stated above if they do not above six feet they can store in a non sprinkled bldg
How much do they want to store??
Is it in a sprinkled building?
You can through the fire code ask the business to supply you with a technical report, to answer any questions you may have about the product and storage,,, from a fire protection engineer or similar expert
