pre-fabricated plumbing vent pipe extensions.
mark handler
So. CA
User friendly plumbing vent pipe extensions to be installed at any location where the plumbing vent pipe height above the existing level of the finished roof system surface does not or will not comply with applicable building code minimum requirements.
Tubos Plumbing | Vent Pipe Extensions
mark handler said:
User friendly plumbing vent pipe extensions to be installed at any location where the plumbing vent pipe height above the existing level of the finished roof system surface does not or will not comply with applicable building code minimum requirements.Tubos Plumbing | Vent Pipe Extensions
I would not except it. Connection of dissimilar material would be one issue, and what if it fell inside the vent stack?
There is a sleeve to prevent it from falling inside the vent stack
is.aspx
Won't work according to code. Mechanical connector required with dissimilar pipe; and they are going to cut it and deliver it to you on the job site? That is plain stupid. All you need to do is use a mechanical connector and use regular pipe off your truck. He is out of business before he started.
