Property Line Markers
cda
Basement
Trying to locate two of my property line markers.
Small residental lot, I have the survey from about ten years ago. Two fence lines were changed, but not that much, soil has been disturbed, also.
I have dug and cannot find them. There are metal fence posts, so metal detector not much help.
Any suggestions, before I call the survey company???
cda,
when they set your property corners did they locate your home and give offsets on a drawing to your property lines. if fences were existing at time of survey did they locate the fences and provide details as to their location in regards to your property corners?
Unfortunately if fences there is a chance that the corners may have been removed. Typically surveyors us something like a 3/4" galvanized pipe or #5 rebar for setting property corners.
GBrackins said:
cda,when they set your property corners did they locate your home and give offsets on a drawing to your property lines. if fences were existing at time of survey did they locate the fences and provide details as to their location in regards to your property corners?
Have the survey, with great distance markers. One fence line was replaced totally, since the survey, and one kind of disturbed
Plus the ground soil has been added to
Will keep digging around a little more, till I get tired of it
Trying to teach my black lab to sniff out property line markers, not working to well
Wonder how accurate a GPS navigator would work. On occasions I've track fishing locations with my vehicle portable GPS using the latitude and longitudes with minutes and degrees feature.
Francis
Francis Vineyard said:
Wonder how accurate a GPS navigator would work. On occasions I've track fishing locations with my vehicle portable GPS using the latitude and longitudes with minutes and degrees feature. Francis
OK I will bite, how do I find out my gps "do heckies" where the markers should be???
GBrackins said:
typically property corners are set about 6-inches below existing grade, at least in all my years that's how we did it. didn't want lawn mowers find them
I might need to dig a little more, the ground level has been disturbed over the past ten years
Ok I get more hints all the time
Been looking for the rear property markers
Some suggested find the front ones and measure to the back!!!
Will be off in the search of the elusive property marker tommorow after work
Found one!!!!!!! Woooo hoo
Three more days off to find the other one!! Thought if I found the first one the other should be straight across according to survey.
Other one is around new fence and dirt has been added to the original elevation
Will keep digging!!!!
When you find them drive a short piece of 1" galvi pipe over the rod and leave 6" sticking out of the ground. Paint pipe orange and you will never loose the spot again.
Found second one. Yea!!! Marked with Galv pipe
Now get to enjoy labor day!!! Then the fence building starts!!!
Just followed the advice of professionals !!!!
Any wood slat fence building advice??
Invest in a nail gun unless you have arms like popeye . Always pull a string line to keep the fence straight. Space the posts a little close unless you own the mythical board stretcher tool. Layout is key. Follow the contour of the land. Most importantly, rent a post hole digger. Good luck.
Whether required or not for maintenance keep the fence at least 6 inches inside your property. Rent a "ground hog auger" at minimum; the other one man or two can wear you out.
Get a few longer slats to follow the contour on grades to allow the top plane have a smooth transistion.
Francis
Would like to use a digger, but building on an easement with electrical, phone, and tv cable buried in it
Have had it marked once, but will do it again before I start
Only have 13 !!! Holes to dig and not in a hurry
