mtlogcabin
Existing single story hospital portion constructed in the mid 70's as a Type IIA. Every addition after that has been Type I A. The hospital is now proposing a 3 story addition over the existing Type IIA completely structurally independant of the original construction. The original columns and beams supporting the original roof will remain. The combustible roofing materials will be removed but the beams and metal deck will remain.
Question: Should the primary structural frame of the original construction be protected as a Type IA OR should it be left as is?
2009 IBC
PRIMARY STRUCTURAL FRAME. The primary structural frame shall include all of the following structural members:
1. The columns;
2. Structural members having direct connections to the columns, including girders, beams, trusses and spandrels;
3. Members of the floor construction and roof construction having direct connections to the columns; and
4. Bracing members that are essential to the vertical stability of the primary structural frame under gravity loading shall be considered part of the primary structural frame whether or not the bracing member carries gravity loads.
The goal is to have a Type IA building when this addition is complete
2009 IBC
1. The columns;
