Protection of Standpipe Laterals/Horizontal Standpipes
Dr. J
Silver Member
Colorado Front Range
Background:
2007 NFPA 14 states:
3.3.1 Branch Line. A piping system, generally in a horizontal plane, connecting not more than one hose connection with a standpipe.
3.3.4 Feed Main. The portion of a standpipe system that supplies water to one or more standpipes.
3.3.11 Standpipe. The vertical portion of the system piping that delivers the water supply for hose connections, and sprinklers on combined systems, vertically from floor to floor. The term standpipe can also refer to the horizontal portion of the system piping that delivers the water supply for two or more hose connections, and sprinklers on combined systems, on a single level.
6.1.2 Protection of Aboveground Piping.
6.1.2.1* Standpipe system piping shall be protected from mechanical damage.
6.1.2.2 Standpipes and lateral piping supplied by standpipes shall be located in enclosed exit stairways or shall be protected by a degree of fire resistance equal to that required for enclosed exit stairways in the building in which they are located.
6.1.2.2.1 In buildings equipped with an approved automatic sprinkler system, lateral piping to 2½ in. (65 mm) hose connections shall not be required to be protected.
6.1.2.2.2 Piping connecting standpipes to 1½ in. (40 mm) hose connections shall not be required to be protected.
6.1.2.2.3 Where exit stairways are not required to be enclosed in fire-rated construction, standpipe systems shall be permitted to be installed without the fire resistance required by 6.1.2.2.
2010 NFPA 14 states:
3.3.11 Standpipe. The system piping that delivers the water supply for hose connections, and for sprinklers on combined systems, vertically from floor to floor.
3.3.11.1 Horizontal Standpipe. The horizontal portion of the system piping that delivers the water supply for two or more hose connections, and for sprinklers on combined systems, on a single level.
6.1.2.2 Feed Mains, standpipes, horizontal standpipes, and branch piping supplied by standpipes shall be located in enclosed exit stairways or shall be protected by a degree of fire resistance equal to that required for enclosed exit stairways in the building in which they are located.
6.1.2.2.1 In buildings equipped with an approved automatic sprinkler system, feed mains and branch lines supplying 2½ in. (65 mm) hose connections shall not be required to be protected.
For a building requiring standpipes that has Horizontal Exits, there will be horizontal piping to 2½” hose valves on each side of the wall adjacent to each exit opening of horizontal exits.
Questions:
Do you agree with me that there is a significant change between 2007 and 2010? It is my opinion that under 2007, this horizontal piping to the hose valves would be considered “lateral piping to 2½ in. (65 mm) hose connections” and therefore is not required to be protected. However under 2010, 6.1.2.2 clearly states 4 classes of piping that need protection, and 6.1.2.2.1 clearly excludes two of these in sprinklered buildings. The two classes not excluded are “standpipes” and “horizontal standpipes” With the new definition of a “horizontal standpipe” it is clear the piping serving the hose valves at the horizontal exit is required to be protected.
The contrary opinion is that 2007 always required this piping to be protected since the definition of a "standpipe" includes piping “that delivers the water supply for two or more hose connections” , and “standpipes” are not included in 6.1.2.2.1 as piping not needing protection. However, the code says a lot by what it does not say. If they meant that horizontal piping serving only a single hose valve does not need protection they would have said “branch line”, which is clearly defined as serving only a single hose valve outlet, and not “lateral piping to 2½ in. (65 mm) hose connections”. They could also have said “lateral piping to a single 2½ in connection”, but they didn’t. Also, note the "s" on the end of "connections" - obviously plural.
Next. Given the requirement for protection in 2010 (and maybe 2007), what is an acceptable means of protection? There is no NRTL test specified to determine the fire resistive rating. Gypbd enclosure I assume is ok. But how about the various wrap systems? Would you accept the same wrap as used for grease duct? How about this stuff: http://multimedia.3m.com/mws/mediawebserver?mwsId=66666UuZjcFSLXTt4XTtNXT6EVuQEcuZgVs6EVs6E666666--&fn=3M_InteramE-5A-4_PDS_4381-3.pdf ? It is specifically listed for protection of electrical feeders and cable, such as for a fire pump feeder.
Weekend code questions you got to love them
Do you read it that the protection is only needed in the stairwell ??
I read code books for fun (used to be bed time stories, but the kids are older now). It is weekend work I love not so much.
No, an enclosed stair is considered protection. The question is regarding piping outside the protection of the stair.
Still trying to decipher it all
I guess a question how often is there more than two outlets on a line?
And once out of the stairwell to me it does not say what the level of protection has to be
ok see if you can decipher this stuff:::
from way down there """"
Committee Statement: It is the intent of the Committee to protect all
standpipe system piping in unsprinklered buildings and to protect only
standpipes and horizontal standpipes in sprinklered buildings. This action also
is intended to maintain conformance with the intent of the IBC.""""""""
14-36 Log #56 Final Action: Accept in Principle
(6.1.2.2 and 6.1.2.2.1)
_______________________________________________________________
Submitter: Roland J. Huggins, American Fire Sprinkler Association, Inc.
Recommendation: Revise text to read as follows:
6.1.2.2 Standpipes, supply mains, and lateral piping supplied by standpipes
6.1.2.2.1 In buildings equipped protected throughout with an approved
automatic sprinkler system, supply mains and lateral piping to 2 ½ in. (65 mm)
Substantiation: It seems prudent to protect the supply main in non-sprinklered
buildings.
Protected throughout is the standard reference for allowing differences when
sprinklers are present.
Committee Meeting Action: Accept in Principle
6.1.2.2 Standpipes, feed mains, and lateral piping supplied by standpipes
automatic sprinkler system, feed mains and lateral piping to 2 ½ in. (65 mm)
Committee Statement: Feed main versus a supply main is a defined term.
Number Eligible to Vote: 23
Ballot Results: Affirmative: 21 Abstain: 1
Ballot Not Returned: 1 Silk, B.
Explanation of Abstention:
ALBINGER, JR.,
14-35 Log #72 Final Action: Reject
(6.1.2.1)
Submitter: Thomas G. Wellen, American Fire Sprinkler Association, Inc.
6.1.2.1* Standpipe system piping shall be protected from fire and mechanical
damage.
Substantiation: The main text for this section only includes mechanical
damage and the annex material indicates protection from fire damage.
Including “fire” in the main text will tie into the annex statement.
A.6.1.2.1 Standpipes should not be placed in unsprinklered areas of
combustible construction.
Committee Meeting Action: Reject
Committee Statement: The committee feels that this topic is already
adequately addressed in the standard.
ALBINGER, JR., P.: See my Explanation of Abstention on Proposal 14-1
(Log #CP10).
Submitter: Donald Brown, Vanderwestern Rutherford Mantecon
Comment on Proposal No: 14-36
Recommendation: Revise text as follows:
6.1.2.2 In unsprinklered buildings standpipes and lateral piping supplied by
standpipes supplying 2.5” hose connections shall be located in enclosed exit
Fire protection of standpipe is not required in sprinklered buildings, or where
there are only 1.5” hose stations, or where exit stairs have no fire rating.
Substantiation: This is to clarify the standard which is being misinterpreted.
Local authorities are applying 6.1.2.2 alone as the minimum even in a
sprinklered building. They then require shaft wall construction or fire wrapping
of the entire standpipe except in stairs or mechanical rooms. The revised
wording makes it clear and combines all 4 conditions of the current 6.1.2.2.
Committee Statement: See Committee Action on Comment 14-24 (Log #27).
Number Eligible to Vote: 24
Ballot Results: Affirmative: 23
14-12 Log #16 Final Action: Reject
(6.1.2.2)
Submitter: Kenneth E. Isman, National Fire Sprinkler Association, Inc.
Recommendation: Reject proposal 14-36.
Substantiation: Action on previous editions eliminated the word ”fire” from
section 6.1.2.1 and placed a note in the Annex explaining that exposed pipe can
be run through buildings of noncombustible construction. During this cycle the
committee was consistent with this philosophy in rejecting proposal 14-35.
However in accepting 14-36 the committee has contradicted their own Annex
note and made it impossible to run pipe through exposed unsprinklered
structures like parking garages.
14-13 Log #27 Final Action: Accept in Principle
(6.1.2.2 through 6.1.2.3)
Submitter: Larry Keeping, Vipond Fire Protection
Comment on Proposal No: 14-8
Recommendation: Revise 6.1.2.2 through 6.1.2.3 to read:
6.1.2.2 Standpipes, Feed mains and lateral piping Feed mains, standpipes,
horizontal standpipes and branch lines supplied by standpipes shall be located
are located.
lateral piping horizontal standpipes and branch lines supplying to 2½ in. (65
6.1.2.3 Where a standpipe or lateral pipe system piping that is normally filled
with water passes through an area subject to freezing temperatures, it shall be
protected to maintain the temperature of the water in the piping between 40°F
and 120°F (4.4°C and 48.9°C).
Substantiation: The terms “lateral piping” and “lateral pipe” are used in the
standard but are not defined, so it is unclear as to what is meant when the terms
are encountered.
As per the Committee Comment for Proposal 14-8, “lateral piping serving
two or more hose connections shall be treated as a standpipe” and as per the
Committee Action on Proposal 13-9 a new definition for a “horizontal
standpipe” was accepted.
Therefore for 6.1.2.2 and 6.1.2.2.1, to avoid any ambiguity, it is suggested
that the words “lateral piping” and “lateral pipe” should be deleted and
replaced with the applicable defined terms “horizontal standpipes” and “branch
lines”.
For 6.1.2.3, any portion of a wet standpipe system that would be subject to
freezing temperatures should be protected, so there it is suggested that the
words “a standpipe or lateral pipe” be revised to the all encompassing term
“standpipe system piping”.
horizontal standpipes, and branch lines supplied by standpipes shall be located
are located.
lateral piping horizontal standpipes and feed mains and branch lines supplying
Any time there is a Horizontal Exit. Each door in a horizontal exit requires two Class 1 stadpipe hose valve outlets. Multiple doors require 2x multiple hose valve outlets. Not uncommon in large buildings like hospitals and university buildings which spread out all over the place and egress distance can not be met without Horizontal Exits.
"by a degree of fire resistance equal to that required for enclosed exit stairways". For a building with 2 hour stair enclosures, that would be 2 hours.
The ROP shows that they were trying to clarify the intent that piping serving 2 or more hose valves is to be treated as a standpipe, and therefore protected. Thus one way of reading it is that it was always the intent of NFPA to protect such piping, they just said it poorly before. the other way, is that said poorly or not, it said something different in 2007 than in 2010, and therefore there are different requirements in 2007 than in 2010.
So, have you guys required piping serving the hose valves at a horizontal exit to be protected, and what is acceptable as protection?
I kind of read it that the protection is required only in the stairwell, and not outside of it.
Agree with your analysis and with the best intentions or atempts the TC has just befuddled it from the 07 to 10.
Regarding:
The way I would interpret it is at what level of separation and rating is the Horizontal Exit? If 2 hr. then 2 hr. protection of the applicable piping just like the stair enclosure etc.... Now on the other hand if the building is sprinkled throughout and on both sides of the rated assembly, then no protection required. Regarding the pipe wrap, I don't have a problem with the material you asked about especially since they still permit heat tracing. Thanks for the request to read...this opinion may not be as good others!
I do not see why if you have a horizontal exit that that would mean you have a two protection for the pipe?
Only the wall of six to twelve inches is rated, possibly if there is a corridor, it may or may not be rated
