Mr. Inspector
2003 A117.1 307. Objects with leading edges more than 27" and not more than 80" above the floor shall protrude 4" max horizontally into circulation path.
We go by 2009 A117.1 now in PA but I don't have it with me now. I don't think this part has not changed.
I get confused with this.
Circulation Path. An exterior or interior way of passage provided for pedestrian travel, including but not limited to, walks, hallways, courtyards, elevators, platform lifts, ramps, stairways, and landings.
1. Can a bank lobby be part of the circulation path. The whole room or only part of it? You need to go through the lobby to get to offices, rest rooms, teller stations, etc.
2. There is a counter in the middle of the lobby to write out deposit slips. the counter only protrudes only 4" on the sides. You need to walk pass the sides to get to the teller stations and there is pleanty of room around the counters. But the counter protrudes 12" out the front and rear. Is this a violation?
3. There are two double teller stations. The tellers need to go by these to get to the work area behind them. The counters on the teller stations protrude over 4" out the sides. Is this a violation?
4. The work area behind the teller stations is less than 200 sq. ft. So they don't need an accessible route to get to this work area.
But is it still a cirulation path?
5. 2012 IBC chapter 11 (tells you what needs to be accessible) never mentions "circulation paths". But it does tell you where you need "accessible routes". Chapter 4 in the 2003 A117.1 tells you how to make an accessble route. "402.2 Components. Accessible routes consist of one or more of the following components: Walking surfaces with a slope not steeper than 1:20, doors and dorways, ramps, crub ramps, elevators, and platform lifts". Nothing here about "circulation paths". Nothing about protruding objects or circulation paths in this section or chapter 4. If this is so should I even be concerned about protruding objects?
