Mr. Inspector
Does the public need to have access to the required service sink? It looks like 2009 IPC 403.3 requires all fixtures required by table 403.1 need to be provided for the public and employees.
2010 ADASAD 212.3 Sinks.And as a heads up, service sink will need to be A117.1 compliant.
Agree that the service sink does not need to be available to the public, that is beside the intent of a service sink. The service sink would be accessible due to the need for employees with disabilities to have equal access.2010 ADASAD 212.3 Sinks.
EXCEPTION: Mop or service sinks shall not be required to comply with 212.3.
I do believe ANSI 117.1 is quite on mop utility and service sinks.
2015 IPC- section 1109 - Operable Parts for Service Personnel do not need to be accessible.
If based on the original question, it is accessible by the public, them it would need to be accessible.
Why in the world would you want a service sink available to the public?
It is for service not for the public....
The codes work together, all sections, all volumes, not each section independent of each other.
And where is that in the code or standards.The service sink would be accessible due to the need for employees with disabilities to have equal access.
on an as needed basis.We would be speaking of the "reasonable accommodation" requirement based on Title I for employees on an as needed basis.
Not public and not per the 2010 ADASAD
Not going to get into employment laws but:Agree that the service sink does not need to be available to the public, that is beside the intent of a service sink. The service sink would be accessible due to the need for employees with disabilities to have equal access.
That would be a good thing.....If the service sink is in a locked closet it would not be available to the public or to some employees.
2010 ADASAD in section 212.3 Sinks. Clearly states NOT Required.
QUOTE]
Not everyone uses the ADASAD - locally we follow the IBC and it's references to ICC A117.1-2009
IBC and ICC A117.1-2009 DO NOT REQUIRE ACCESSIBILTYIBC and it's references to ICC A117.1-2009
