HVACQuestions
I have some lab spaces using plenum style return systems, does this mean I need to fire wrap any existing PVC piping above the ceiling in those areas? I don't see anything in IMC that stipulates this.
It is more than just plastic piping that comes into play when you have a plenum space. I would review all of 602.2.12018 IMC
602.2.1.7 Plastic plumbing piping and tubing.
Plastic piping and tubing used in plumbing systems shall be listed and labeled as having a flame spread index not greater than 25 and a smoke-developed index not greater than 50 when tested in accordance with ASTM E84 or UL 723.
Exception: Plastic water distribution piping and tubing listed and labeled in accordance with UL 2846 as having a peak optical density not greater than 0.50, an average optical density not greater than 0.15, and a flame spread distance not greater than 5 feet (1524 mm), and installed in accordance with its listing.
Be careful what you use to wrap the pipes withdoes this mean I need to fire wrap any existing PVC piping above the ceiling in those areas?
