Quantico MCB Bachelors Enlisted Quarters
What can you do with military barricks? It's a big box with a bunch of cubes inside. I've seen way worse........
ICE said:
Were there bars on the windows?
DOES KIND OF REMIND ME OF SING SING
I've bunked in a hell of a lot worse! Field toilets 6" apart. Now that togetherness. Infested with mosquitoes. Air conditioning? Whats that? Television? Maybe if you had a day room.
Life without a television.....shoot me now!.....Nowadays you can tweet what you're thinking.....this is the generation that lives inside the television.....one becomes their own entertainment with their own sitcom.....you can catch the next episode on Facebook.
ICE said:
Life without a television.....shoot me now!....Nowadays you can tweet your displeasure
Well, just so you all know, I have not had a television for years. Every time I travel and turn the TV on at the hotel I understand why.
Missiles in Romania. Poland after that site is complete.
Architecturally, contractors on most military bases must conform a particular type and that varies from base to base, region to region. Contractors at Marine Corps Quantico Base use planning standards found in the Base Exterior Architectural Plan. Any design over the top or not the norm will not be accepted.
I thought that I read somewhere that the DoD had adopted
the ICC family of codes to use.
If the the MCB Quantico Project is using the BEAP, what
about the ICC codes?....Do you know if the DoD uses them
at all?.....Also, I seem to recall that the U.S. Naval
Construction Forces had adopted and were using the ICC
codes..........Do you have any info ?
