quite urgent (Need help with retrieving previous version of a file)
KRQK
Denmark
Hi
It is quite urgent. I have accidentaly messed up with on of my drawing & I wish to retrieve one of its previous version. I checked at help & it says I need to go to revision history after going into the project list. But the problem is I can’t see any option to go to project list. Can I get some help regarding this. The drawing is quite important & urgent.
If you are looking for help with drafting software you will need to state what software and version that you are using. You might have success trying a forum specific to drafting or your software.
Hi the version is 20.2.30. That is all I could see in ``About``.
It appears that this only applies when you have been using the cloud-based Project Studio within Bluebeam. If you have been saving it (and uploading it) you open Studio and the project, then right-click on the file name (under Studio Project - NOT under the standard 'File' pull-down) and you'll see "Revision History" towards the bottom. If you haven't saved it to Studio there isn't any saved history to restore.
Seeing how this is in the Bluebeam section, I thought it was Bluebeam. Oh, yeah, it is Bluebeam Revu.
This would be the official and correct answer.
