Ready for deck framing inspection
Forum Coordinator
Somewhere Too Hot & Humid
Are you really ready?
attachment.php
/monthly_2015_05/IMG_0097.jpg.60eb6677c301b7429d98bbe684d2a8e3.jpg
Jeff is on his game today ! :D
Uuuuuuuhhhhmm, ...NO, they are not ready for a
Framing inspection.
They need each opening in the support brackets to have
the manufacturer' fastener correctly installed in them.
Exactly how did they attach that rim board to the existing
ledger board ?
Since the framing is that close to grade, I will ASSUME
that the boards are all pressure treated, or other suitably
approved type wood for a wet environment.......If using
pressure treated wood, I will need to physically see each
nail \ screw that has already been installed, to verify
that they are an approved type of fastener that can be
used in pressure treated wood [ i.e. - yeah, ...pull all
of them out & start over ].
Regarding pulling fasteners, I will generally tell the inspector to pick his 2 favorites and I will back them out.
That has always sufficed if it's an issue.
Brent.
Or you could just match what's in the hanger with what's in the box sitting (most likely) by the screw/nail gun...
"Or you could just match what's in the hanger with what's in the box sitting (most likely) by the screw/nail gun..."
As long as what is actually being used in "that box sitting by the nail gun"is what the manufacturer requires, otherwise pull `em all out and start
over.........It is not my problem if you damage the brackets when removing
the nails.........Go buy some more "new" ones and install them correctly the
2nd time.
