LGreene
I'm trying to find "proof" in the IBC of something that I thought I already knew, but I'm having trouble.
Imagine a vestibule, with a pair of doors on the interior (leading from the lobby to the vestibule) and a single door on the exterior. I didn't think that was allowed because it reduced the egress width from +/- 6' at the pair, to +/- 3' at the single.
In the IBC, I found this, which supports what I thought I knew:
1003.6 Means of egress continuity. The path of egress travel along a means of egress shall not be interrupted by a building element other than a means of egress component as specified in this chapter. Obstructions shall not be placed in the minimum width or required capacity of a means of egress component except projections permitted by this chapter. The minimum width or required capacity of a means of egress system shall not be diminished along the path of egress travel.
But in the Commentary, it says:
Note, however, that the egress path could be reduced in width in situations where it is wider than required by the code based on the occupant load. For example, if the required width of a corridor was 52 inches (1321 mm) based on the number of occupants using the corridor and the corridor provided was 96 inches (2438 mm) in width, the corridor would be allowed to be reduced to the minimum required width of 52 inches (1321 mm) since that width would still serve the number of occupants required by the code. In the context of this section, a “means of egress component” would most likely be a door or doorway.
If the occupant load of the building is 100, for example, isn't the Commentary saying that it's ok to have a pair of interior doors and a single exterior door, since the single door provides sufficient egress width? Is there another section of the IBC that affects this?
Thanks in advance!
- Lori
Thanks in advance!
- Lori
