aaron@rollingsarchitects.
We designed a 10 stall bathroom as a tornado shelter.  Extra studs, stand alone structure, cmu drystack in the walls, extra sheathing, etc.  Our issue is the door.  The door itself is metal reinforced, heavy gauge, with push-pull hardware.  To secure the door in case of a tornado there are three deadbolts.  The deadbolts have thumbscrews on both sides, so if the people inside cannot operate it, it can be opened from outside.  Our local authority is saying the door needs to be operable per 2015 1010.1.9.5. "The unlatching of any door or leaf shall not require more than one operation."  He is not allowing us to have the three deadbolts.  We have reinforced hardware that will comply with code but they will not work with the push pull operation wanted by the owner.  Does anyone have any ideas on how we can work around this?
Thanks
AAron
			Thanks
AAron
