Or screw the unit ONTO the deck after final . . .FredK said:Just so everyone's on the same page it's "fixed seating". Figure it'll take some clown about 5 minutes to unscrew the unit from the deck.
This will effectively ban fixed seating alongside of a guard, while still offering a "choice".High Desert said:Don't like the code change. What's the difference between fixed and movable furniture...and I know, we can't regulate furniture. I am only saying the same hazard exists whether fixed or not. They should have just banned fixed seating when the deck required guardrails.
Another problem is the term adjacent fixed seating. Athough the figure show shows it attached to the guard, that's not what the code says. Adjacent does not mean attached. It could be in the middle of the deck and could be interpreted as being "adjacent."cboboggs said:Here is the actual code section."R312.2 Height. Required guards at open-sided walking surfaces, including stairs, porches, balconies or landings, shall be not less than 36 inches (914 mm) high measured vertically above the adjacent walking surface, adjacent fixed seating or the line connecting the leading edges of the treads."
although a platform the size of a landing would be a walking surface, , , floor, , , I have approved that in the past with existing situationsHigh Desert said:cboboggs: I see where you're going but the code actually says "not more than 44 inches above the floor."
