Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,384
The 2018 IPC uses in t403.1 and the IBC occupancy classification issue has been brought up many times, so not a new conundrum, but a new situation. I interpret the IPC to go by the uses in the tables, not the IBC classifications. IPC line 2 for business occupancies, and line 4 for factory industrial both use the term "industrial". Line 2 uses "light industrial" in the "description" column, while line 4 uses "industrial" in the "classification" column.
Consider a vehicle repair garage, IBC calculated OL at 24, used for the repair of fleet vehicles only. No outside public contingent. Clearly an IBC S1 (MAQ's not exceeded), not a B, but not clear in the IPC tables where it would fall. If I use line 4 I don't get to use the exception for under 26 occupants and separate facilities are required. If I use line 2, I get the exception and separate facilities are not required.
Interested to know how anyone else sees this and which IPC table line would be used.
