Forum Coordinator
OK Plumbing gurus, anything wrong with this setup?
YOU make the call!
YOU make the call!
2006 IPC: 906.2 Venting of fixture drains.globe trekker said:Jobsaver,Might you be referring to Section P3105.2 in the 2006, ...instead of Section
906.2.1 in the IPC?
What's the problem? (opens spigot in basement and demonstrates water draining out of waste stack)globe trekker said:Jeff,Did you, or do you apply the DWV testing requirements of Section P2503.5 - DWV
systems testing, on these drain lines?
