Any thoughts appreciated here. I recently had a conversation with my AHJ regarding the CFM requirements for residential range hoods. Mechanical code says nothing useful, IRC says 100 CFM intermittant/25 CFM continuous. >400cfm requires a makeup air unit. All fine. However, some of the inspectors are of the opinion that the AHJ has the right to reference the range manufacture's recommendations/requirements for hood CFM rather than the code- apparently based on total BTU output of the range. I understand that code is the minimum standard. I also appreciate and respect the importance of indoor air quality, mechanical ventilation etc. However, two issues come up here. 1. range manufacturers vary widely in their recommendations, some have none at al, many just reference a "pairing" of their own hoods with their ranges. 2. makeup air units for a cold climate are incredibly expensive and complex. We avoid these in all cases except for the really big 42"+ commercial style home ranges. First question is, at what threshold do we really concern ourselves with 400CFM being inadequate to vent a gas range. Second question is, if the range is electric, or induction, what are the criteria for CFM? If its a BTU output issue, a 48" induction range can put out some serious heat, comparable with a gas range, albeit without the combustion byproducts.
