Residential Swimming Pools
globe trekker
How would ya'll classify a "new" Residential In-ground Swimming Pool being built
at an existing residence, or would you classify it at all? A Type "U", or...
Thanks! :)
Hmmmm.....a bit odd to me.......since IRC residential structures don't really have an occupancy classification themselves........... call it a U and move on I guess.
globe trekker said:
How would ya'll classify a "new" Residential In-ground Swimming Pool being builtat an existing residence, or would you classify it at all? A Type "U", or...
Thanks! :)
If you must classify then I would call it a "U". It is afterall an "accessory structure". My thoughts for this statement are that there will be electrical and concrete work done along with the grading, permits are required therefor it becomes a "U" occupancy.
Sue, where the west still lives.........
Hi globe trekker, has the person requiring you to assign a classification said why? The reason I ask is that (as fatboy said) residential structures are not classified in the IRC as they are in the IBC.
I would go along with a U... and besides a U almost has the same shape as a pool, or a coffee cup U°.
Something along the lines of "a Residential, accessory use, below ground structure,
but nothing defined in the IRC" thingy. :D
In that case I would just go with a "U" classification - that covers anything that falls under miscellaneous -
Accessory structure...
R101.2 Scope. The provisions of the International Residential Code for One- and Two-family Dwellings shall apply to the construction, alteration, movement, enlargement, replacement, repair, equipment, use and occupancy, location, removal and demolition of detached one- and two-family dwellings and townhouses not more than three stories above grade plane in height with a separate means of egress and their accessory structures.
Don't see 'U' anywhere in there.
The would be a "WSS"
I think I would go with a mixed use occupancy if there are many occupants it would be an A5, if any of the occupants were sleepy on a floating thing it would be an R, if they talked business it would be a B.
How about creating a new mixed use occupancy P= Private Facility, O=Operation, O=Outside, L=Lake like, POOL.
