Valid question but I have no idea and would like to keep this discussion from getting diverted.No overflow drain adjacent?
Jeff made me do it.
Sooooooo, **ICE**, ...how did the topic go from a [ possible ]
defective roof drain to a CBS new reporter ?
1 Yes. it is broke and will allow debris into the drain1) Would you require that the drain dome in the below photo be replaced?
2) Would the plumbing inspector also be called to this job as this is covered in the IPC?
Reporter Weijia Jiang Announced Her PregnancySo what happened to Weijia Jang. She was a reporter on the CBS evening news for a few months and now she is gone.
Maybe a scupper nearby?No overflow drain adjacent?
That was the first thing that I noticed.No overflow drain adjacent?
2012 IPC
1105.1 General.
Roof drains shall be installed in accordance with the manufacturer’s instructions. The inside opening for the roof drain shall not be obstructed by the roofing membrane material.
I challenge you to find a manufacture that does not include a dome strainer with their roof drain.
"Zurn Roof Drains are comprised of three basic components: a body (sump), a combination membrane flashing clamp/gravel guard, and a dome strainer."
