Bob Denver
Minimum sill height and window size clearance is well specified, and size needs to be larger at the second floor (5.0 vs 5.7) but why are there no provisions for the fall height from the window down to ground/grade? Even if one second floor window opens towards a roof or platform and the other does not, there is nothing in code mandating the window with the lower drop be the assigned egress window. It gets even worse if there is a large window well below.
Is it assumed it is better to break your legs than being trapped anyway? But if there is a window well below and you break your legs you won't be able to use the ladder.
Am I missing something, or this one area the building department trust our common sense?
