globe trekker
- Joined
- Oct 19, 2009
- Messages
- 1,739
I have an existing residence that is enclosing a porch area on the rear of the house.
Presently, I cannot confirm that a 3' - 0 " x 6' - 8" door is installed in the structure
( per Section R311.4.1 in the `06 IRC ).
The plans indicate that when the enclosure is built, they will be installing a set of
2' - 6" x 6' - 8" French doors in the "new" enclosed area.
If they do not have a 3' - 0 " x 6' - 8" door at the front, I am asking that they
install one at the rear [ instead of the two 2' - 6" x 6' - 8" French doors, or two
3' - 0" x 6' - 8" French doors ]. The problem is that they want to build a new
deck outside the the "new" enclosed area and there are steps leading up onto the
deck, which will restrict access to exiting away from the residence.
Essentially, persons exiting the house will go through the new compliant Exit Door
at the rear [ if required ], travel horizontally approx. 2.5 ft. and then up 2 risers
onto the deck.
If they do not currently have a compliant exit door at the front and they want to
install the two - 2' - 6" x 6' - 8" doors at the rear, how would "exiting to the
exterior" be accomplished? How far away from the "habitable portions of the
residence" ( per Section R311.4.1 ) is required?
Are there another code sections that I can refer to regarding this?
Thanks!
onto the deck.
Thanks!
