This is what is being used. All tie wraps for every box and wire in the place.
AndIn some instances, these home made devices:]
Home made devices? In Florida those are called "similar fittings".jar546 said:
Designed and install by true Florida craftsman.334.30 Securing and Supporting. Nonmetallic-sheathedcable shall be supported and secured by staples, cable ties,
straps, hangers, or similar fittings designed and installed so
as not to damage the cable, at intervals not exceeding 1.4 m
(41⁄2 ft) and within 300 mm (12 in.) of every outlet box,
junction box, cabinet, or fitting. Flat cables shall not be
stapled on edge.
Sections of cable protected from physical damage by raceway
shall not be required to be secured within the raceway.
They are not corrupted, they are gone from the old system which did not communicate well with the new system.All of the pictures in this thread are corrupted.
