Separate Your Drawings Policy
One of the biggest headaches in plan review, especially when multiple disciplines are involved, is how details get scattered across drawings. This is a major issue in high-rise condo remodels and extensive single-family home modifications, where architects tend to draw everything—including MEPs—on a single set of plans. To save space, they’ll drop framing details on Mechanical, Electrical, or Plumbing sheets, and sometimes a plumbing riser diagram ends up on an architectural page. To make matters worse, all their sheets are labeled as “A” pages instead of properly separating them by discipline. It’s not unusual to see a set labeled A1, A2, A3, A4, A5, and A6, with the last three actually being MEPs.
This mixing of disciplines creates a lot of unnecessary confusion. When these come in as a single file, we require the applicant to separate them—architectural pages in one file and MEPs broken down accordingly. If Electrical has multiple “A” pages, they can be kept together, but they must be properly identified. Otherwise, when a plumbing reviewer comes across a ceiling framing detail on an “A” page labeled for plumbing, they have to notify the building reviewer. If plumbing approves the page, they have to stamp it PLUMBING ONLY to prevent a contractor from pointing to a framing detail on A6 and claiming it was approved. It’s a ridiculous problem that could be avoided if plans were submitted correctly in the first place. That’s why we now reject plans that mix disciplines on a single page. Since all our permits are all-inclusive—covering Building, Plumbing, Electrical, and Mechanical—having clear, organized files keeps things consistent and reduces mistakes.
At this point, with everything being digital, is there any valid reason for design professionals to keep cramming multiple disciplines onto a single sheet? The old excuse of saving paper doesn’t apply anymore, yet architects still act like they’re paying per sheet. All it does is slow down the review process and create unnecessary back-and-forth.
  1. How does your municipality handle this?
  2. Are you seeing the same issue, or do you have policies in place to force discipline separation from the start?
There is no conceivable reason for doing this. I know AutoCAD, I don't know Revit. Doing what you describe would be ridiculous using AutoCAD. Since Revit is also an Autodesk product, much newer than AutoCAD, I'm pretty certain it would be equally contraindicated in Revit.
We have not seen this. Not even from the unlicensed "building designer" clowns.
We have not seen this at all. I have never seen a planset from an RDP that was not properly broken out.
Our plan reviewer reviews all disciplines, so a framing note on the plumbing page could likely be dealt with without much trouble as a one-off, but it would become a major pain if they started doing what you described.
I'm working on changes to a 1960s HS all on around 30 drawings when it was built. Recently I worked on a new HS with over a 1000 sheets. I can't imagine why anyone wants more sheets, which guarantees more conflicts. This is why the quality of drawings has gone into the toilet over last 50 years. Love those plan drawings that show the wall section as a little bubble on the plan, rather than 50 sheets further into the set. And all those sheets that are basically backgrounds with only a couple of little bits of unique info.
I've not run into this. If the drawing is stamped, is the architect able to stamp MEP drawings?
It probably varies by state. Architects receive education in M/E/P (and structural, for that matter). In my state we are allowed to practice all engineering disciplines "when incidental to" the architectural work. I think most states are similar.
In practice, most architects don't want to do anything more than very minor M/E/P design, and they usually do an incomplete job on the drawings even then.
BUT ... an architect (or engineer) is only supposed to stamp drawings if he/she prepared the drawings personally, or if the were prepared under the architect's direct supervision. By sealing them, he/she is accepting liability for ten.
OK. It's the same here. Sounds like it might be more than "incidental" in Jar's case.
