Seperation of gas from other utilities
DMartin
GREENHORN
Newton Kansas
Good Day,
As far as I knew there had to be a separation of gas from other underground utilities of 12" if perpendicular and 3' if parallel. I was looking for it to cite the code section but I can not find it. Has this been removed or does anyone have a code section cite?
Thank you for your time.
Thanks maybe it was just through hearing it from others that I thought this was the case. I will look into local utilities regulations but even then out of my hands now.
Most utility companies do have seperation charts, may not be in code but check with the utility companies
Good Day,
Is this on public or private property?
Thank you I was able to get confirmation from the gas company that my initial thought was correct except they want a 5 foot separation form electric.
