Inspector Gadget
Unless epoxy.Possibly. Tell me what i missed. But grout is not waterproof, it is porous.
The point being made here is that regardless of the stud system, a standard tile installation will allow water to permeate to the wall assembly - the only question is "how much," and whether it will cause problems. On a wood-stud, interior wall, the old-school Wonderboard base will be more than fine. (I am not saying that's Code, but that it's a past practice that ought not to cause problems.)
I can easily see how tile on wonderboard on steel studs could cause a corrosion problem. I wouldn't do that without waterproofing or some other methodology in place (at the very least, vapour barrier between the board and the studs, but even then....)
Canadian Codes only require that tiles in a shower/bathtub are installed on a "moisture-resistant" backing. Technically, that's greenboard (which is now purple) but as a former tile guy, I can tell you that I won't be doing that when I finish the house this summer: the new waterproofing membranes are ah-maz-ing, and work like a hot damn.
Bottom line: y'all can't install bathroom tile over ordinary gyproc, whether by code or best practice.
