The following excerpt is from this article "The Difference Between a Fire Alarm Annunciator and a Control Panel" at
When an alarm is triggered, whether it’s a smoke detector sensing smoke or a heat detector detecting high temperatures, both the annunciator and the control panel receive the signal. This allows for immediate visual and audible notifications to alert building occupants of the potential danger. The annunciator and control panel also have the ability to display the specific location of the alarm, allowing for quick identification and response.
Questions:
1. Does the annuciator receive signal through the control panel or directly from smoke or heat detector?
2. Does the control panel display the same information as the annuciator?
Educate Yourself now on the differences between a fire alarm annunciator and a control panel. Read Now!
pavion.com
Similarities Between Annunciator and Control Panel
Both the fire alarm annunciator and the control panel play crucial roles in a fire alarm system. They work together to provide comprehensive monitoring, detection, and notification capabilities. Additionally, they are typically connected and share data, enabling seamless communication between the two components.When an alarm is triggered, whether it’s a smoke detector sensing smoke or a heat detector detecting high temperatures, both the annunciator and the control panel receive the signal. This allows for immediate visual and audible notifications to alert building occupants of the potential danger. The annunciator and control panel also have the ability to display the specific location of the alarm, allowing for quick identification and response.
Questions:
