Single Motor Tap Calculation per the NEC
I know of three people on this forum that can easily do this. Let's see if I am right. Here is the question for those who want to give it a try. Everything you need to calculate the answer is in the question and in the NEC.
A 25-hp, 230-V, 3-phase squirrel-cage motor is to be supplied from a branch circuit that has 2/0 AWG THW copper conductors, which have an ampacity of 175 A. See Table 310.16. Determine the correct size for the tap conductors less than 25 ft.
2020 NEC: Per 430.28 exception: feeder taps under that condition will be at 125% of FLC found in table 430.250 (68 amps x 125% = 85 amps.) Conductor size will be #4 copper THW at 75 degrees Celsius.
Minor quibble: the OP describes a branch circuit tap, not a feeder tap, so the applicable NEC section is 430.53(D). This assumes the branch circuit as a whole meets the requirements of 430.53(B) or (C).
Cheers, Wayne
Cheers, Wayne
One-third of 175 A is 58 A. The tap conductor normally would be sized at 6 AWG THW copper (65 A). But a 6 AWG tap conductor does not meet the requirements of 430.22, that is, 125 percent of the full-load current of the motor (68 A from Table 430.250), or 85 A. Therefore, the branch-circuit tap conductors are not permitted to be smaller than 4 AWG THW copper, with an ampacity of 85 A. See Table 310.16.
I agree with your computation, which also matches post #2. But it has no particular bearing on my post, so I'm not sure why you quoted me.
Cheers, Wayne
