steverray... yes, you can easily provide unfettered access. This is not the point. The point is how the code is actually and specifically written versus its supposed intent. (Nice rig by the way... what year is that? I have an '07 JK)
The point is this: Table 2902.1 lists "1 service sink" as a required fixture for all occupancies (except in R and some I occupancies). It does not say anything about how to calculate the number of required service sinks for a building with multiple occupancies. The footnotes for this table do not state "The code requires only one service sink per building if all occupancies have access to the service sink at all times." This sentence is not in the IBC or the IPC. It only appears under the tables for two solution summaries in the code commentary. If the "intent" or "proper interpretation" of the service sink requirement is for one sink per building, the ACTUAL code should say this. It should be easy enough to add footnote "F" to the table...
I started this thread in order to get help finding that language in the actual code. I discovered that it is not, in fact, in the actual code. Even after two subsequent published versions, it is still not in there. After speaking with a rep from the ICC, I found out that the ICC cannot just add this common sense language into the code on it's own accord... it must be submitted through a committee to be reviewed, voted on and formally adopted into the next version.
Well... here goes nothin'...
