Smoke Barrier Duct Openings
Mech
Eastern PA
2009 IBC
I-2
Smoke Barrier w/ 1 hour fire resistance rating separating the building into at least two smoke compartments.
710.3 Fire-resistance rating. A 1 hour fire-resistance rating is required for smoke barriers. Exception: Smoke barriers constructed of minimum 0.10 inch thick steel in Group I-3 buildings.
For duct penetrations through the smoke barrier, I assume a smoke damper AND a fire damper (or combination smoke / fire damper) is required. Is this correct?
Thanks
Thanks Ron.
It seemed odd to me to require a one hour fire rated smoke barrier but not require the duct penetration to have a fire rated damper.
Only a smoke damper will be installed.
