Question That
iecc 2009 SC.
Prescriptive path.
Have a situation (again) where ideally a steel beam is directly above a light guage metal stud wall.
I can incorporate the continuous insulation requirement no problem and bypass the beam flanges.
the R19 requirement is where I'm having trouble getting my head wrapped around.
technically I can't get R19 at the beam (unless maybe I spray foam between the flanges at the exterior side) unless I bypass the stud wall past the beam at the exterior (which I don't want to do.
Wondering how the iecc views this detail. I'm thinking they "want" the wall to bypass the beam but wondering what my options are.
Note that curtain wall will bypass some of these beams at different levels of the building so not quite sure how that factors into the equation.
Thanks.
Prescriptive path.
Thanks.
