conarb
I'm curious as to how many here are enforcing the residential control joints in stucco? In the past this has been ignored in single family residential construction, but apparently not anymore. Since this is controverisal here is a pretty good look at the controversy.
¹ http://www.wconline.com/CDA/Archive/0d6db97b2b768010VgnVCM100000f932a8c0____The International Building Code and most model building codes reference ASTM C1063, the Standard Specification for the Installation of Lathing and Furring to Receive Interior and Exterior Portland Cement-Based Plaster, as the lath installation specification. C1063 makes no differentiation between control and expansion joints—however, let’s consider control joints to be one-piece joints and all two- or three-piece joints, including back to back casing beads to be expansion joints. Generally, the industry uses the terms interchangeably. ASTM C1063 states, “Control joints shall be formed by using a single prefabricated member or fabricated by installing casing beads back to back with a flexible barrier membrane behind the casing beads. The separation spacing shall be not less than 1/8 inch or as required by anticipated thermal exposure range (per author and to accommodate stucco shrinkage).” It goes on to state that it has to conform to the previous section that states the following: “Lath shall not be continuous through control joints but shall be stopped and tied at each side.” The specification continues: “Control (expansion and contraction) joints shall be installed in walls to delineate areas not more than 144 square feet and to delineate areas not more than 100 square feet for all horizontal applications, that is, ceilings, curves, or angle type structures. The distance between control joints shall not exceed 18 feet in either direction or a length-to-width ratio of 2 1⁄2 to 1. A control joint shall be installed where the ceiling framing or furring changes direction.” Finally, it states, “A control joint shall be installed where an expansion joint occurs in the base exterior wall. Wall or partition height door frames shall be considered as control joints.”¹
