Kevin Stokes
Good evening all,
I'm a Realtor who is working with an investor to buy a studio here in Austin. The inspection report cited R302.5.1 in regards to the attached garage and I'm seeking input on the following issue:
Is an attached garage that leads into an open studio floor plan a violation of R302.5.1?
The code reads:
R302.5.1 Opening protection. Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 13/8 inches (35 mm) in thickness, solid or honeycomb-core steel doors not less than 13/8 inches (35 mm) thick, or 20-minute fire-rated doors, equipped with a selfclosing device.
The garage access door opens directly into the kitchen area of the studio, but there is no physical separation between the kitchen area and bedroom area.
Thoughts?
The code reads:
Thoughts?
