334.30 Securing and Supporting. Nonmetallic-sheathed cable shall be supported and secured by staples, cable ties, straps, hangers, or similar fittings designed and installed so as not to damage the cable, at intervals not exceeding 1.4 m (41⁄2 ft) and within 300 mm (12 in.) of every outlet box, junction box, cabinet, or fitting. Flat cables shall not be stapled on edge.
yes, that is what the code reads. These straps are hand made from other materials and not listed but,........nothing says they have to be so these are an approved method we accept.
Thats some nice looking work.
Here is the rub
Notice all the 1900 boxes are on the exact same position as a mortar joint.
There is no control line snapped on the CBS.
Hoping for the best for that electrician after the floor guys level across and the tree killer set their base cabinets.
And im wondering why the used foam or caulk where the nm goes through the wood blocking
It only has to hold it long enough to pass inspection.staples allowed into mortar vs block?
