Taking Gray-Water Recycling From DIY to the Mainstream
mark handler
So. CA
By the touch of a remote, the water going down your shower drain could be diverted to water your garden.
Take a shower or do a load of laundry, and you’re most likely wasting some amount of water.
That’s because gray water, the water that ends up in the drain from these sources, can be used to irrigate our lawns and gardens but oftentimes is not.
For residents in the drought-stricken western United States, that could easily change, says Santa Monica resident and self-described tinkerer Garry Sato.
“It’s the way I think most people in our region can participate [in water conservation], be proactive, and not have to suffer,” Sato said.
Sato has an invention he believes gives residents a new way to conserve: a wireless, remote-controlled gray-water system he calls the diverter. The product is the first of its kind to have met requirements for the Uniform Plumbing Code, a stamp of approval needed by plumbers and building inspectors to install for widespread use, Sato says.
Gray-water systems are not new, but they have largely been accessible to those with a DIY spirit—or the money to get a system installed. And despite a reported rise in gray-water system installations in the past year, off-the-shelf products have been limited.
RELATED: Is the Best Way to Beat the Drought Against the Law?
“I decided to make my own [system] because there wasn’t anything out on the market to use at home,” said Sato. “The ones available were mainly for industrial use at refineries, tankers or nuclear subs, and overkill for a household.”
Here’s how it works: The diverter replaces a 14-inch piece of pipe from a home’s existing shower and laundry drainage system that leads to the sewer. Its extra valve-operated opening directs the flow away from the sewer, through the new pipe, and to an irrigation hose—allowing users to water their lawns with the recycled water. The hose can run through the home into one’s yard via a 1.5-inch hole drilled into the side of the house or the foundation, he added.
“The most simple system will involve hooking up the pipe to a garden hose,” Sato said.
Users can open and close the valve—choosing to water or not water their yards—by pressing a button on a portable remote control.
The water conservation implications for such a system are huge. On average, one person uses a few dozen gallons per day for showers and laundry—making up about 60 percent of the water consumed in a household. With the diverter, an average household could save up to 4,000 gallons of water per month.
According to Sato, no other doctoring to the plumbing system or house would be needed for the basic setup. He uses the system to water his garden, moving the hose around to different parts of the yard he wants to irrigate the night before.
But where the water goes is really up to the user. The hose can run to temporary storage tanks designed to filter or disinfect water, then pump it out for either toilet flushing or landscape irrigation.
Local gray-water regulations can also determine how residents set up their system. In California—where the system might be needed most—the plumbing code requires users to follow several best practices, such as not to store gray water unless it is filtered or disinfected first, as it may contain bacteria and start to smell. According to Oakland-based Greywater Action group, gray water isn’t safe to drink but there have been no documented cases of illness in the U.S. transmitted via gray-water systems.
Sato wants California to emulate Tucson, Arizona, which passed legislation requiring that all new construction built after June 1, 2010 be gray-water system-ready—the same way new houses in California are required to have the hookups installed for an electric vehicle charging station.
In July, Sato met with Assemblymember Richard Bloom (D-Santa Monica) about his idea.
“We’re interested in how we can expand the use of gray water,” said Sean MacNeil, Bloom’s spokesperson. “We don’t know what all the options are right now, but considering the drought, now seems like a good time.”
Though his product will be on the shelf in limited release at five Southern California–based Ferguson plumbing stores by early October, Sato is looking forward to late next month, when he’ll demonstrate the diverter for officials with the city of San Francisco.
Common practice in the 1950's in the south to run the graywater to the flower beds. Then the rules changed and it was not allowed. I guess somethings come full circle unless the this product violates some old rule somewhere.
What happens if the sewer backs up when the valve is in the open to sewer position? It looks like raw sewage can flow up through the valve then down into the irrigation system.
I like the simplicity of the design, in concept at least. I also have concerns regarding cross-contamination.
NEXUS EWATER GREY WATER RECYCLING SOLUTION
http://www.turfmagazine.com/water-features/nexus-ewater-grey-water-recycling-solution/
Nexus eWater is introducing a system to recycle homes’ grey water so it can be reused on landscapes and in toilets, reducing homeowners’ potable water usage by more than 35 percent. The company’s home water recycling solutions are attracting the interest of California builders. Bob Hitchner, the company’s chief marketing officer, shares how the system works.
What is the history of the company and why is it now located in San Diego, California?
We started in the grey water business in Australia, which endured a decade-long drought into the early part of this century. Australia was forced to innovate earlier than the U.S. in using and reusing water in safe and effective ways.
Through this experience, we learned how important it is to develop solutions that will work automatically in the background without active homeowner engagement.
When we set up a new company to explore new product innovations, we immediately decided to set our sights on the U.S. market. The U.S. market is larger and has not yet really addressed the deeper questions of how to reorganize its infrastructure and even its lifestyles to use water more effectively.
When we knew that we would be the first company to certify an onsite solution to the NSF-350 standard for grey water, which is required in the California Plumbing Code, we knew we needed to move the core of our operations to California.
What exactly is NSF-350?
The NSF-350 standard is the gold standard for certifying equipment for on-site grey water treatment. This certification ensures the equipment is designed to consistently treat grey water to a high level of quality that is safe to use in non-potable applications.
What interest has Nexus received from homebuilders in offering your technology in new homes?
Homebuilders have three good reasons to incorporate our solution in their homes:
To prepare for a possible future when water for landscapes is restricted even more than today.
To build their brand and learn how to build homes that are livable even in extreme or long-term drought.
To address homebuyer concerns about preserving home resale values during more extreme drought.
What do you see as the role of Nexus in conserving water, particularly on landscapes?
California water policy is changing very quickly right now. Our solution is merely one tool for translating good policy into everyday practice.
In several years, I hope every new home in California will be dual-plumbed so it can easily upgrade to onsite water recycling at any point in its lifetime.
How much does a typical installation cost, and what do you estimate the ROI to be?
Each installation can be quite different. Some homebuyers, especially in the high-end custom home segment, also want expansive service to come as part of what they buy. So costs range from $10,000 to $15,000, including all labor.
Since buyers today want to protect their landscape investments, payback is virtually immediate.
