Absolutely-- the code in most cases will require 2 rods as one rod will not get anywhere near 25 ohms in this area-- nor will 2. I was responding in jest about being tough guys, because many areas do not enforce 2 rods for a pole. I do realize the code makes no exception for a temp. pole. On a home I use a ufer simply because the rods cannot come anywhere close to what a ufer can do-- at least around here. I got 89 ohms on 2 rods- worthless- but I got 13 ohms on a ufer on the same site. NC has amended the ufer rule and I wish they would enforce it. The rods, IMO just satisfy code and do not much more-- this is why they don't push it for a temp. pole.
